HFSS problem- Mesh segments could not be obtained
Zero304
Newbie
Newbie level 1
I work on a project on HFSS, but every time I run the simulation the following error shows and the solution is terminated:
[error] Adaptive solution setup, process hf3d error: Mesh segments could not be obtained for an edge of terminal Array1_T1 assigned to port port1.. (9:46:10 AM Feb 07, 2022)
[error] Simulation completed with execution error on server: Local Machine. (9:46:10 AM Feb 07, 2022)
What are the possible causes for this problem?, and how can I solve it.
Thanks a head for your time, regards.
