[SOLVED] HFSS no far-field radiation result option, even though I added my Infinite Sphere
xingdachen
Newbie
I try to simulate a curved antenna, but there is no far-field pattern option for my result. I had already created an Infinite Sphere and I was expecting the far-field result option.
Screenshot here:
Solution
It may have to do with your simulation type, which is "Modal Network". Are you able to change this to "Driven Modal"?
I haven't used the 2022 version, so this may have simply been a change in naming convention.
After inserting an infinite sphere, right click on Results, an chose "Create Far Field Reports", 3D Polar Plot..
Thanks for the reply vfone.
I do understand that. But after I insert the infinite sphere, there is no option for "Create Far Field Reports" (screen shot above refered)
I wonder if it had to do with my antenna itself?
Solution
