alffnot
Member level 1
hi, i am new to learning HFSS so i am designing a directional coupler with microstrips and simulating in momentum and comparing the simulations in HFSS to see if i am using HFSS right.
i designed the directional coupler to couple at at -10 db, simulated just using ADS and give me exactly -10db, simulated using momentum it gives me -11.5dB. using same exact substrate, widths, etc and HFSS gives me a coupling of -8.5dB. is this typical, i have tried changing port size in HFSS, radition boundry and and just about every parameter i can find in the solution setup. and the results stay about teh same.
i'm kinda stuck, i can't seem to figure out what it could be, any ideas would be appreciated. thanks
