paszczakojad
Newbie level 6
I'm trying to simulate a waveguide diplexer using HFSS. I found in some documents, that the solution frequency used during adaptive meshing of a filter should be inside the passband of that filter - otherwise the mesh is dense enough only near the ports.
But how to do this when simulating a diplexer that has different passbands for each arm? When I used frequency inside first passband I got perfect simulation of the first filter response and bad of the second one. Similarily when I used the other passband frequency. But I need both simultaneously.
The only way was using low lambda target for lambda refinement (0.05) or applying appropriate mesh operations to create dense mesh and disable adaptive meshing, but that created hundreds of thousands of tetrahedra and the simulation time was a few times longer (and still less accurate).
I thought about making adaptive meshes for each arm separately and merging them together, but I wanted to make some optimizations, so I need this process to be automatic. I wish there was a 'mesh operation' consisting of adaptive meshing of selected solids using specified solution frequency.
Best regards,
P.
Best regards,
P.
