nschutten
Member level 3
how to select two ports at a time in hfss
I am currently designing a two port (diversity) metal stamped antenna, using HFSS.
Simulating S-parameters is straight forward, and I can view a far field result, but I am not sure what excitation port (Waveport1 or Waveport2) this far field originates from.
Does anyone know how I can generate far field reports of my dual port antenna, first one with Waveport1 as excitation, then one with Waveport2 as excitation, so that I can also observe the difference in radiation pattern and hence the diversity gain?
Thanks in advance!
Thanks in advance!
