Meow_Qin
Newbie
Hi, I have some problems when simulating Ground(G)-Signal(S) structure transmission line using HFSS. Below is the model. As for the GSG coplanar waveguide structure, the waveport should intersect both of the ground signals to define the signal electrode. My model only has one ground electrode and one signal electrode and the structure is symmetrical. I need to calculate the S parameter, characteristic impedance and effective indices of the two ports. The waveports are set according to the slotline port with an integration line marked in the picture. However the results are wrong. I want to know how to set the waveports correctly. Many thanks!
