goatmxj666
Member level 3
Hello. I am importing a gds file into HFSS.
Originally, when I clicked file -> import -> GDSII and opened the gds file, a window popped up where I could set the Technology file and Layer map file.
However, after reinstalling the program, when I open the gds file, the window to set the Technology file and Layer map does not pop up and the gds is not imported.
I don't get any error, so I don't know how to solve it. Even when I select the gds file and click “open”, nothing happens as shown in the picture below.
Please help, I don't think it's an installation issue because the previous hfss file completely formatted my computer. (Additionally, Importing via Modeler->import doesn't suit me).
The file isn't even a wrong file - It opens normally via HFSS on others' PCs with the same version.
I ended up importing the GDS file to someone else's PC, then extracted the HFSS project file and opened it on my PC.
I then ran the simulation and clicked on “solution data” to extract the S-parameters, but nothing happened.
Normally, a window should pop up where I can set up the S-parameter file format to extract.
Does anyone know of a solution?
* When I imported the gds file.
* Results -> Solution Data
https://innovationspace.ansys.com/f.../2/2024/10/04-10-2024-1728032262-mceclip0.png
