rpm4159
Hello, it is clear how to specify the layer destination/color/thickness etc through a layer mapping file for Cadence to HFSS gds files. However, the layout Im looking to bring into HFSS includes layers of a different datatype that are critical and need to be mapped as well. For example I may need to map layers 64:0 and 64:16 and the layer mapping resources Ive seen only allow a single numerical value for the import #. Is there any information on how to add different datatypes to the layermap file? I'm asking if there's a manual way or through adding it to the map file but eventually I want to just script the entire process though one file if that makes it easier (layer map and tech/substrate data).
Thank you
Thank you
