HFSS exports DXF in meters even though my design is in mm — how to fix this?
imtiaz369
Member level 3
Member level 3
I made a antenna model which have top conductor, substrate and bottom conductor in HFSS 2024 R2, where all my model dimensions are in millimeters. However, when I export the geometry using Modeler > Export > DXF, the resulting DXF file treats all dimensions as meters.
For example, a 30 mm dimension ends up as 30000 meters in the DXF, which completely breaks scale when importing into other tools like ADS or CAD software. (ADS or KiCad detected it as a very large size)
I confirmed this by importing into QCAD, and yes — the drawing is 1000× larger than expected.
❓ Is there a way to force HFSS to export DXF in millimeters, or at least apply unit conversion during export?
If not, what’s the most efficient way to deal with this?
Appreciate any tips from those who’ve dealt with HFSS → DXF → PCB/ADS flow!
Every CAD tool I've used has a DBU (database unit) setting and/or a UU (user unit) and DBU/UU conversion factor. May be in an init file or maybe left to default.
Likewise other tools' import setup ought to inquire (may be pre-filled) about incoming DBU, UU but not necessarily obvious
Write your reply...
LaTeX Commands Quick-Menu:
