circular_loop
Newbie
Hi everyone. I have created a design for an elliptical loop antenna using design attached. It's an outer ellipse with an inner ellipse cut-out(to form an empty space inside), and a rectangular cut-out for input and output. When I wanted to export the layout into a dxf file for further fabrication, it turned out to be something very weird. Apparently, the lower end of an inner ellipse connected with the upper end of an outer ellipse, and similarly upper end of an inner ellipse got connected to the remaining node. Pictures attached.
I have tried to modify the dxf file as the elliptical(or whatever mine faulty one is called) shape is represented as a bunch of dots connected together. Unfortunately, I couldn't manage to do this and modifying otherwise presented much of a burden. I would greatly appreciate any help related here.
Thanks.
Thanks.
