trichop
Junior Member level 3
HFSS error: Adaptive solution, process solver : Insufficient memory for subprocess "%
I run a big mesh simulation in HFSS, therefore I upgraded my PC, from 1Gbyte RAM, to 3GByte!
However, when I run the simulation at frequencies of 2GHz and higher, after the 6th or 7th pass this error appears:
[error] Adaptive solution, process solver : Insufficient memory for subprocess "%3".
Although previously the programm warns me that the mesh is too big or the frequency is too high (something that happens either if you have 512MB RAM or 3GB )
the memory that is allocated at the specific pass is very low (~400MB) and does not seem to run out of memory.
Whatsmore, in the previous succesfull passes, the memory allocation does not exist 1.5GB.
Does anybody have a clue about tis error?
