HFSS ePhysics application
dpxiao333
Junior Member level 1
ephysics
Hello,
I am planning build a large signal model for power transistor including thermal effect.
The website of ansoft shows that ePhysics can coupled thermal analysis for Electromagnetic application. I have not use HFSS before and It seems to me that HFSS is mainly for passive components, so I am wondering can this software be use for active component simulation.
And can it be used to analyze the thermal effect on transistor large signal model.
Thanks in advance.
hfss+ephysics
in order to do a simulation of active components, you need to use both Maxwell and HFSS. then you'll import the model into ePhysics.
You'll find more information on the website www.ansoft.com
berser.k
