HFSS - Can you reverse a "Unite" operation - i.e. have an "Ununite"?
DeboraHarry
Full Member level 5
Full Member level 5
UK
In HFSS if I unite objects A and B, but don't save the file, I can always Undo the operation.
But after saving the file, is there any way I can reverse that operation?
My question was asked 6 years ago by someone else
https://www.edaboard.com/threads/65779/
but the only reply is not very helpful.
Deborah
Re: HFSS - Can you reverse a "Unite" operation - i.e. have an "Ununite"?
Still there is a possibility to cancel through "Delete Last Operation" (Select you object - a click of the right button of a mouse - Edit - Delete Last Operation).
In HFSS 14 you can delete the Unite function anywhere in the Geometry tree anytime. All objects will be un-united.
Have Fun
Have Fun
Thank you. Is that true in HFSS 13? I do have a machine with HFSS 14 on it, but also use HFSS 13 on another machine. It so happens the machine which has the object I want to delete has HFSS 13.02 on it.
BTW, I started another thread on a topic we discussed before.
https://www.edaboard.com/threads/261652/
I'd appreciate if you took a look at that. This time I put it in the correct forum (EM Simulation). I don't think this thread about "unite" was the right forum for this question, but it is not too far off. Compared to things like rainfall and other things that have appeared in the RF/EM forums, this is not too off-topic!
Deborah
