[SOLVED] HFSS 3D Layout - Define PCB Differential Waveports
boboKof
Hi everyone,
I'm new with HFSS 3D Layout. It is a bit different than the HFSS 3D CAD.
I'm trying to define 2 waveport over 2 differential nets. Both is on TOP layer and the reference ground is at Layer 4.
The main problem is that I get an Error trying to use Layer 4 Ground as negative for both ports.
Thanks for your help!
Hi everyone,
What is the error? Also, layer 4 is a poor return current path, as your return current will be constrained to L3 and L1.
I though the return pass is in layer 4, but it actually in layer 3.
Thanks for noticing and for your help.
