Ow@i$
Advanced Member level 1
I am designing a HF receiver for WWV signal (10 MHz)... can its front end.. i.e Selectivity and amplification be done through an IC ??? if yes kindly give me he name of that IC ??
Thanx guys.. I just found a link which i guess will done the job for me instead of an IC, the link is :
One question now I have is, the final output of that circuit will be audio ... however WWV (10 MHz) signal also has BCD coded time information... how to extract that one???.. which i guess is Pulse width modulated.. also where in this circuit that digital part is removed??
@ BradtheRad thanx, correct me if i am wrong but the 1Mohm and 0.001uF cap in the receiver front end (**broken link removed**) that forms high pass filter with Fc=159 hz.. isactually filtering out the Digital subcarrier??? Plz need help i am stuck there!!!
isn't their configuration is totally satisfying the configuration of a High pass filter.???...i mean how come they would know that they don't have to filter but instead provide Blocking and definite DC ground...
