Hercules Ruledeck Format Manual
ftflorendo
Newbie level 1
Newbie level 1
Hello!
I am new in Synopsis Hercules.
I am more comfortable in using Cadence Dracula and a little bit of Mentor Graphics' Calibre.
My problem is that I can't find manual for the rule deck format of Synopsis Hercules.
Can anyone provide me with the link?
Also any tips for the differences of these ruledeck formats will be very helpful.
Assuming you have a valid installation, licensing, etc, there should be a directory of PDFs somewhere in there. Among those is (if it is like what I saw years ago) "index.pdx". This is a compiled index across the doc suite, and opens in Acrobat. (Possibly also equivalent PDF readers, though some of them don't handle the search correctly.) The links there should take you to the correct general area.
To locate the directory with the PDFs on a Unix system, you can use the find command: find . -name "*.pdf"
This will give you the full path of all PDF files below the directory you are in. (If you are desperate enough to kick it off from /, try find . -name index.pdx instead, and hope they haven't renamed the index file in the past decade.)
