|IAngel|
Member level 3
Hi all,
I installed Cadence IC5033 at school on a bunch of computers in my lab and it worked fine. I tried doing the same at home and I get a whole lot of X TOOLBOX errors. ICFB loads and then everything freezes. As it appears that none of the GUI components are properly working, this makes sense. For example:
\o X Toolbox Warning: String to TranslationTable conversion encountered errors
\o X Toolbox Warning: translation table syntax error: Unknown keysym name: osfUp
\o X Toolbox Warning: ... found while parsing '<Key>osfUp: EditCell(Up)'
\o X Toolbox Warning: translation table syntax error: Unknown keysym name: osfBackSpace
\o X Toolbox Warning: ... found while parsing 'Meta<Key>osfBackSpace: delete-previous-word()'
\o X Toolbox Warning: String to AcceleratorTable conversion encountered errors
\o X Toolbox Warning: ... found while parsing '<Key>osfUp: listUpDown(0)'
Does anyone know how I would fix this? Is it an environmental variable issue?
Thanks!
|IAngel|
For a more complete list fo the errors, there is almost an exact replica of what I get in
EDIT: Oh, and for the record - I'm using a startCds script written by the school. When I try and start it directly with simply "IFCB &" it gives me an error and won't load. I run startCds, however, and it loads - only with all those erros.
Looking forward to suggestions
Thanks!
|IAngel|
