gezzas525
Full Member level 3
As i described in a previous post now when placing pins, for example the invertor, I placed an IN, OUT vdd! and a gnd! I DRC and extract the design OK. Viewing the extracted layout the nmos transistor is the wrong was round. Now when when it comes to simulate I have to specify the IN the vdd! and gnd! however they are not under global nets but under inputs. Leaving the gnd input as it is and setting IN and vdd! gives me an error as follows
fprintf/sprintf: format spec. incompatable with data -nil
however using any name for the supply without the exclamation mark works fine and I obtain simulation results.
does anyone have any ideas, iam beginging to think that it could be an OS/library issue?
KLEOS
KLEOS
