--jason--
Junior Member level 2
hi,
i am designing a two quadrant bidirectional dc-dc converter whereby at the input side, it is an input sources 48v (can be an energy storage unit:ultracapacitor) and at the output side it can connect to a dc motor drive with a regulated dc output voltage 100v.
i am using an inductor with 5.7mH (choke inductor) and an output capacitor with 0.01F. The inductance and capacitance values that i get are based on the current ripple and voltage ripple formula from the boost converter.
At the first, i tried at an open loop condition by input a fix duty cycle without load and after that i loaded it with a resistor of 36ohm.
without the load, the current ripple is small and when i'm loaded with 36ohm resistor, the current ripple was high and not the same as what i am calculated from the formula of boost converter.
somebody can help me? i will very appreciate your help, thanks.
