Help with Triac Control for up to 50mA Gate Trigger Current using TXC10M60
ramanh
Newbie level 3
Newbie level 3
Hi there is it possible that someone can help me with the above Phase control IC.I'm encountering some problems with the Application example - Triac Control for up to 50mA Gate Trigger Current.I've reduce the AC voltage to 26V AC too suit my circuitry,which drives a 24V 150W halogen lamp.With this I changed some resistors for eg Rsync is 27K and the input resistor is 390 ohm and also changed the TXC10M60 with a common used TIC225M triac.
No luck with the circuit.Help please
txc10 m60
change the capacitor value,increase that value of 10th and 12th pin capacitor.if u change input voltage means u have to change the design,so give 230 v AC,,as per the circuit,,,check the ground properly,otherwise shorted,,,,,,,,
try u will suceed
