0.4" (10 mm) trace/copper pour width isn't necessarily impracticable...
...Imagine the track end segment as a triangle with a corner at the pin rather than a round pin of full track width...
...I'm thinking to use 2 OZ copper board with track width of 86 mils, accourding to the calculator it works fine.
...if possible go for a bus bar...
For specified current of 15A it is not necessary...
Even for a greater rating of 40A I already used with a BTA41, track metalization is quite enought.
...it may help to reduce the PCB size...now a days everything is becoming smaller...
