BrunoARG
Full Member level 4
- Joined
- Aug 15, 2014
- Messages
- 214
- Helped
- 38
- Reputation
- 76
- Reaction score
- 38
- Trophy points
- 28
- Location
- Buenos Aires, Argentina
- Activity points
- 2,177
Hello everyone
I am working in a small personal project which is a poor man's soldering station, or so. I have made the complete diagram, the solder iron and hot air gun connection and sensors positioning, the 1st order (proportional) temperature controller with PWM output which will activate an opto diac, connected to a triac and the heaating element.(yes, won't control the output power via PPM to avoid any complication).
The matter here is.. I bought a thermocouple, but they couldn't tell me what type it was. All I know is that this one is used in stoves, as safety protection, when there is no flame, gas won't flow outside.
So I did some research and found this:
And the thermocouple is this one:
Junction head
Connector
I had to see what was inside, so I decided to get into it...
This is the conenctor. You can see a copper wire insulated with a sort of cheap fiberglass thread. A brass piece connected to it, an insulator ring and the external "copper" tube.
This is the junction or metals welding. They look the SAME color but the end of that filament was actually part of the "copper" core.
And I made the following tests:
Took a fridge magnet, and realised that (as thought) the outside "copper" tube was not magnetic, but the silver-looking head did.
The metal that looks silver and is welded to the head is NOT magnetic, but the head is.
So, there are two posibilities:
K type --> Nichrome // Ni-Al
J type --> Iron // Constatan (Cu-Ni).
By the color of the core ("copper") it must be Ni-Cu (because nichrome looks silver).
By the color of the head, being magnetic, it must be IRON, and it should be because it's the other metal used in the thermocouple.
I am pretty sure it's a J-type thermocouple, then. But how about the external tube? The core is Ni-Cu and the outside is something with copper (or just copper, doesn't matter), it should be the same material as the second metal (iron) or it would generate another seebeck potencial in the joint (at the end of the head).
I don't understand this thermocouple, can you help me please?
Junction head
Connector
