gentleoyink
Hello, I would like to learn how to write a testbench for a FSM.
Please can you help me write a suitable test bench for the code below. (Please I developed this code to be as simple as it can. However the knowledge gotten from learning it would be applied to a more bigger situation/code).
sorry, here are the codes
-AND SECTION -
-- Subsection AND Gate
library ieee;
use ieee.std_logic_1164.all;
entity andgate is
port (g, h, bit : in STD_LOGIC;
z : out STD_LOGIC);
end andgate;
architecture behavioural of andgate is
Begin
process (bit)
begin
if bit = '0' then
z <= g and h;
else
null;
end if;
end process;
end behavioural;
-OR SECTION -
-- Subsection OR Gate
-- VHDL libraries for standard logic
library ieee;
entity orgate is
port (x, y, bit : in STD_LOGIC;
d : out STD_LOGIC);
end orgate;
architecture behavioural of orgate is
Begin
process (bit)
begin
if bit = '1' then
d <= x or y;
else
null;
end if;
end process;
end behavioural;
-CONTROLLER SECTION -
library ieee;
entity controls is
generic(n : integer := 4);
port
(adds, addin, clock, reset: in STD_LOGIC;
ans : out STD_LOGIC);
end controls;
architecture behavioural of controls is
component andgate
z : out STD_LOGIC);
end component;
component orgate
d : out STD_LOGIC);
end component;
type states is (none, a, b); --Defines the type of states in the state machine
signal state, next_state : states;
signal added, func: STD_LOGIC;
begin
fsm: process (state)
begin
case state is
when none =>
next_state <= a;
when a =>
next_state <= b;
when b =>
next_state <= a;
end case;
end process fsm;
fsm1: process (clock)
begin
if (reset = '1') then
ans <= '0';
else
if (clock'event) and (clock = '1') then
case state is
when none =>
ans <= '0';
when a =>
added <= '1'; func <= '1';
when b =>
added <= addin; func <= '0';
end case;
end if;
end if;
end process fsm1;
m1 : andgate port map (adds, added, func, ans);
m2 : orgate port map (adds, added, func, ans);
end behavioural;
Thank you for your assistance.
-AND SECTION -
library ieee;
entity andgate is
z : out STD_LOGIC);
end andgate;
Begin
process (bit)
begin
if bit = '0' then
z <= g and h;
else
null;
end if;
end process;
end behavioural;
-OR SECTION -
library ieee;
entity orgate is
d : out STD_LOGIC);
end orgate;
Begin
process (bit)
begin
if bit = '1' then
d <= x or y;
else
null;
end if;
end process;
end behavioural;
library ieee;
entity controls is
port
end controls;
component andgate
z : out STD_LOGIC);
end component;
component orgate
d : out STD_LOGIC);
end component;
begin
begin
case state is
when none =>
next_state <= a;
when a =>
next_state <= b;
when b =>
next_state <= a;
end case;
end process fsm;
begin
ans <= '0';
else
case state is
when none =>
ans <= '0';
when a =>
when b =>
end case;
end if;
end if;
end process fsm1;
end behavioural;
