Help with solving simple circuit
olakease
Newbie level 2
Newbie level 2
Formula to get voltage on circuit
Maybe this is a Do my Homework question, but I'm learning Electronics and I'm confused on solve a simple Circuit.
The value in Voltimeter is 6.43 V, but, how can I get this value with Analysis? I mean, exists a formula for this?
Thank you.
this is strange normally you should have 6v in the voltmeter, are you sure that the supply is exactly 6V ?
Yeah, is only a simple example.
I'm trying another Simulator and the Value is 6V, but, the real question is how can I get this value with a formula?
normally you should have 6v on the voltmeter, if you really have 6V as a source
you don't need a formula, the voltage on the line when you put the voltmeter is simular to the value of the source
Total Voltage will be 6V-voltage at the junction 5k&2k. for the analysis of 1.5V, the current will flow through the 2k & 5k only. so the current is -1.5/(2k+5k)=-0.214mA, so @ junction the voltage is -0.214mA*2k=-0.428V, hence the total voltage 6-(-0.428)= 6.428 or 6.43V.
This only in the case of ideal circuit, assuming, there is no resistance on the 6V path, so that no current flow.
i made a simulation using Lt spice but i did get this 6,43 V that you mentionned
