Tripp_22
Newbie
I'm trying to make make kids toy that normally takes 3 AAA batteries run off of a rechargeable 18650 Li-ion battery.
This is the toy:
RC Bumper Cars
I purchased this board from amazon:
MakerFocus 6pcs 2A 5V Charge Discharge
As well as these micro USB breakouts in case I need them to charge the battery:
The cars run on around 4.2V-4.8V. I would like them to be ran on a steady voltage of around 4.7V as that is when they have the best performance. I also need to make sure the battery doesn't get ran below its minimum safe voltage (probably around 3.6v or so).
I tried the black charge/discharge/boost board from the amazon link above but it seems to have some sort of protection circuit that triggers as soon as I connect it to the rc car. I have one of the same motors that the car uses laying around the house so I tried that as well and the board turns off as soon as I connect the motor. The board works fine if I hook it to a simple load like 8 x 3.3v LEDs.
Here is a link to what the motor is like:
I'm guessing that it is trying to pull to much current from the board but I don't really know for sure. The board says it can handle 2A so that seems strange The car pulls about 200-300ma when operating normally but it must have an amp spike or something when the motor first starts turning because the car just stutters when I hook up my power supply to it with 400ma limit. It starts running properly around a 800ma limit on the power supply (4.7V), but I only ever see 200-300ma on the readout.
So my question is, can someone offer me some better equipment examples to get this thing converted to run on an 18650 battery? Or tell me what I'm doing wrong with the stuff I already purchased.
My son and I will greatly appreciate your help as we really love playing with these things but they go through batteries too fast.
Thanks.
This is the toy:
RC Bumper Cars
1.5-6 VDC MOTOR
• Ideal for battery-operated projects • 27 x 20 x 15mm • 2mm diameter shaft • Solder-loop terminals
www.allelectronics.com
Thanks.
