joeygemma
Newbie level 6
- Joined
- Sep 10, 2010
- Messages
- 14
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- South Carolina, USA
- Activity points
- 1,384
I'm building a switching voltage regulator using an LM2675. I am converting 28VDC to 5VDC @ 1A. The 5V end is USB and needs to be able to charge an iPhone. The entire circuit works and I have voltage going to D+ and D- (about 1.5 and 2.0 respectively).
I used the resistor layout from Ladyada (MintyBoost - The mysteries of Apple device charging) to adjust the voltage for D+ and D-. Her voltage comes out differently, which I can't figure out. She has one resistor from each D pin to 5V and one to ground, which I also did. My question is can I just use a resistor to go from 5V to 2V and 2.8V without another resistor going to the ground?
Thanks for your input.
