Help with OrCAD - adding component to library
kot_b
Full Member level 1
Latvia
Help with OrCAD
Hi, guy's!
I need help with desining with Candece PSD14.2!
The first question may be:
How can i add my component to library?
It is easy. Open the library (you want to add the component to) in your design project, then expand the cache, drag and drop the component into the library.
So it's mean, that before i have to create a compoment? How can i do this?
in a dsn, you will find library docunment,press your rignt piont,and then add a lib file ,go on pressing lib file,right piont of your mouse,then can creat new part........
if you want to gen part libs to new olb,
press dsn,then tools/generate parts.........
in detail,see the book of orcad
Hi
only way to make a new part is by making and storing it in a library, for that
1) open new library from file->new project-> library menu
2) selct .olb from the tree window and right click to add new part
then draw the part and save it.
3) open a new design project and place new part, add the library you made in the dialog then place the part...
Regards
Asterix
