promach
Anyone have any idea on how to better optimize the following priority-if statements ?
STATE_IDLE :
begin
// for simplicity, idle state coding will only transit to STATE_ACTIVATE and STATE_REFRESH
// will implement state transition to STATE_WRITE_LEVELLING and STATE_SELF_REFRESH later
// Rationale behind the priority encoder logic coding below:
// We can queue (or postpone) up to maximum 8 REFRESH commands inside the RAM.
// If 8 are queued, there's a high priority request.
// If 4-7 are queued, there's a low-priority request.
// If 0-3 are queued, no more are needed (both request signals are false).
// So READ/WRITE normally go first and refreshes are done while no READ/WRITE are pending,
// unless there is a danger that the queue underflows,
// in which case it becomes a high-priority request and READ/WRITE have to wait.
// So, in summary, it is to overcome the performance penalty due to refresh lockout at the
// higher densities
if((refresh_Queue == 0) &&
(user_desired_extra_read_or_write_cycles <= MAX_NUM_OF_REFRESH_COMMANDS_POSTPONED))
begin
refresh_Queue <= user_desired_extra_read_or_write_cycles;
end
if ((MPR_ENABLE) ||
(extra_read_or_write_cycles_had_passed & high_Priority_Refresh_Request) ||
((user_desired_extra_read_or_write_cycles == 0) & it_is_time_to_do_refresh_now))
begin
// need to do PRECHARGE before REFRESH, see tRP
ck_en <= 1;
cs_n <= 0;
ras_n <= 0;
cas_n <= 1;
we_n <= 0;
address[A10] <= 0;
main_state <= STATE_PRECHARGE;
wait_count <= 0;
end
else if (write_is_enabled | read_is_enabled)
begin
ck_en <= 1;
cs_n <= 0;
ras_n <= 0;
cas_n <= 1;
we_n <= 1;
bank_address <= i_user_data_address[ADDRESS_BITWIDTH +: BANK_ADDRESS_BITWIDTH];
main_state <= STATE_ACTIVATE;
wait_count <= 0;
end
else if (low_Priority_Refresh_Request)
begin
ck_en <= 1;
cs_n <= 0;
ras_n <= 0;
cas_n <= 1;
we_n <= 0;
address[A10] <= 0;
wait_count <= 0;
end
else main_state <= STATE_IDLE;
end
