saburo
Newbie level 6
Hello,
I am trying to understand how to use mosftets and drivers, I am still quite at a basic stage and my electronics knowledge is limited (I am more into the "software" world, but I'd like to change that).
Problem :
I have some DC source (i.e solar panels) which can give me about 80V (could vary, but to make it simpler let's assume 80V ) and about 5A.
ideally I would like to create a DC switching circuit (buck, boost, sepic... does not matter, just trying to focus on the mosfet part for now).
I want to use a mosfet, will probably use an IRF NChannel, 100V about 10A+ with the lowest Rdson possible.
This one IRF3710 is a bit an overkill, but looks nice and should run pretty cool.
The issue is that those kind of mosfet don't have a "logic level" Gate, so I need a gate driver to "amplifiy" my pwm signal.
At 10-12V Rds should be pretty low (20 is normally the maximum for the FETs I spotted).
I could go for transistors, but investigated dedicated devices instead as they seem to offer interesting configurations and fast switching, and finally they contain transistors too.
So I had a look at these two :
PMD9050D
PMD2001D
An I was thinking to test them with a circuit like the following :
In this circuit I used the PMD2001D, which is a totem pole driver (just learnt that name and the basics of how it works )... as I did not figure out how the other one works so far.
Now the calculations and relative questions:
1) the PMD2001D has a collector current of 0.6A with 1A max for short cycles (that would be likely my case I guess, using PWM from 30KHz up), I assume even the 0.6 should be enough for the IRF (could not find a Igs value in the datasheet) I guess that depends on how fast you want to switch it since it is voltage controlled, correct?
2) It's V ratings go up to 40V, so should do to carry my 12V in the configuration I chose (load is on the high side of the mosfet)
3) hfe is around 200, so even a tiny 5mA current provided by the pwm signal should reach the maximum output, however I saw in the datasheet (table 7) values for Ib = 20 and Ib= 50mA which does somehow conflicts with what I find in Fig 6.. wouldn't that be way too high since the device can deliver a max of 1A? With that value in mind I calculated the 120 Ohm value for R1, bu it does not make a lot of sense to me, I would have sized it for about 5-15mA (Fig 6) instead depending on the needed Gate current of the fet
Plus, if I have to provide more than 20mA with an MCU I would need to "drive the driver", which kind of defeats the purpose, no?
4) Even accounting for the voltage drop in the driver the 12V should be enough (11.something V) to switch cleanly the Mosfet, right? anything over 7-8V should bring down Rdson to very low values according to the datasheet, still 12 is way less than the 20V max allowed, so I figured it's a safe value.
5) I added a pulldown resistor (R2) with an arbitrary 10K value to ground the driver's base when the pwm signal is low, not sure it is needed, but found it in some schematics and suggestions around the web. Is that correct?
6) the cap across the two collectors of the driver is added as a filter, found that in a**broken link removed** (which I still need to digest, just exploring for now) on the Ti website.
I am sorry it's all really messy, but that's actually the way it is in my head right now
I am hoping for someone to help me in shredding some light on this fascinating subject.
Thanks in advance.
Problem :
PMD9050D
PMD2001D
Thanks in advance.
