elimenohpee182
Newbie level 2
help with mosfet biasing
I'm confused on how to calculate the Vds voltage when trying to use a mosfet as a switch. In my attachment, the source is grounded and the load is connected at the drain. If for example I'm using this mosfet:
how would I be able to calculate the voltage at the drain? I ask because the current Id seems seems it is a function of the gate voltage and the drain-source voltage. The whole purpose is to switch a led that requires 1amp and has a voltage drop of 3.5V. Also, how would you go about picking the proper resistor value R?
If you can explain why and how you chose your values of voltage and resistance that would be so appreciated!
