Help with modify VIA in Allgero PCB editor!
lemta
I have copied VIA default in database then modify drill size and pad size and save as with new name, but when use it seems to does not show drill hole (figure below, blue rectangle)
Any help? Thanks so much!
hi,
you have to call the path of via setup-->user preference-->library-->pad path and psm path after that add in constraint manager in physical constraint.
I have tried setup but still does't not show drill symbol, can you send me the file which make via with drill 0.5mm and diameter 1mm?
Hi
check the attached via details and bring it in design as i mention in above procedure
  • pad40d20.rar
Hi Kabaleevisu,
I have replaced current via with your but still does not show drill (it like via in blue rectangle, I want to it shown as via on the left.
I have sent you my via file (drill 0.5mm and size 1mm). I can't to know what is wrong :(
  • via_drill20.rar
Manufacturer-->NC-->Drill customization as shown in picture change the value you come to know,is it drill is available are not or else setup-->design parameter in that Display tab choose Display plated holes and padless holes it will show the drill point
Reactions: lemta
    lemta
Now I can see it, thank you :), also I'm not sure about the feature that: when I have clicked on component in layout plus , orcad capture will focus it on screen, but with pcb editor it do nothing?
