Joshp689
Hello everyone,
This is my first post, so its a welcome and help thread.
I drew a simple circuit that I need help with
Am I understanding this correct, the LEDs are in parallel so volts is the same through each LED, but current will be divided among the 10 LEDs? LEDs are essentially a "short circuit" so they will allow as much current as possible, and pop? So I will need to lower the volts and current. the next image is my understanding of how to do this.
I want R1 to use .8A, so using Ohm's Law (V=IR) I would go 5V/.8A=6.25Ω. That will leave me with 5V .2A going to the other part, now I need to lower the volts so I would go (Vs-Vf) 5-3=2 2V/.2A=10Ω.
Let me know if I did any of this wrong. Before you ask there are other strands of LEDs that will require more current than this example, that's why I am using 1A.
