markoverclock
Newbie level 1
I need help with a problem im trying to fix. I have an fuel injector signal from the ecu on my car 0-12volts i think or its 0-5. The voltage changes from 0-??? but its always a negitve signal.
I need to basically make an electronic relay. it will need to be capable of switching up to about 150 times a second and i believe be able to carry up to 15amps.
Im using this to create a rpm signal from the fuel injector signal, but i need it to always output a 12 volt flashing signal without altering the original 0-??? ranging singal sent to the fuel injector. Help would be great and if someone out thier could help me make one of these i will deposit some money into thier paypal account.
I need this to finish a project for my friend before i move. Thanks in advance. the cheaper the better.
