simple answer:
* you clearly apply HIGH
* but you never apply LOW
A floating signal is "undefined". It may be HIGH, it may be LOW, it may oscillate, it may pick up noise / signals from nearby, it may change state at any time...
--> use pulldown resistors as Brad already mentioned.
Btw:
* almost every beginner made this mistake. Thus on a search you may find millions of the same informations that Brad and I just gave. Just do a search.
* if you have a simulation tool ... then use it. You used a LED to check the output state of a gate ... but the same way you could use a LED to check the input state of a gate
Don´t use external file servers. Just press the [insert image] button to add a picture.
Klaus
