Help with Bode plots for Loop Compensation with LTC3810
Rocketmagnet
Junior Member level 3
Hi all,
I'm trying to design a DCDC regulator with the LTC3810 from Linear. It seems to be a great little chip, but there's one part of the design that's slightly out of my league:
Loop compensation...
According to the datasheet, I need to generate a bode plot of the behaviour of the system, and from that I can calculate the required loop compensation components. According to the datasheet, I fill in the component values into this SPICE code:
*3810 modulator gain/phase
*2006 Linear Technology
*this file simulates a simplified model of
*the LTC3810 for generating a v(out)/v(ith)
*bode plot
.param rdson=.0135                 ;MOSFET rdson
.param Vrng=2                      ;use 1.4 for INTVCC and 0.7 for ground
.param vsnsmax={0.173*Vrng-0.026}
.param Imax={vsnsmax/rdson}
.param DL=4                        ;inductor ripple current
*inductor current
gl out 0 value={(v(ith)-1.2)*Imax/1.2+DL/2}
*output cap
cout out out2 270u                 ;capacitor value
resr out2 0 0.018                  ;capacitor ESR
*load
Rout out 0 2                       ;load resistor
vstim ith 0 0 ac 1                 ;ac stimulus
.ac dec 100 100 10meg
.probe
.end
Then plot the Gain and Phase of v(out)/v(ith). However, when I do this, the Gain curve looks OK, but the Phase looks nothing like the example one on the datasheet. For a start, it seems to be upside down, so I plotted v(ith)/v(out) which now seems to be the right way up.
But, no matter how I fiddle the values in the SPICE code, I cannot get it to look much like the example graph from the datasheet. I.E. most of the Phase curve is greater than -90. In mine, all of the Phase curve is less than -90.
Can anyone sort me out? Many thanks in advance.
Hugo Elias - Shadow Robot Co Ltd
P.S. the other thing that seems to be strange is that there's no value for output inductance in the SPICE code!
forum dedicated to LTSpice on yahoo groups for you.
-tell you will produce many thousands products with their chips
I was actually hoping to avoid using that nasty little program.
