doncarlosalbatros
Full Member level 2
For an enclosure, I will control the power at the terminals of a panel mount AC socket by using an SSR. The AC mains socket will have this indicator lamp in parallel to indicate whether the socket is live/powered. The indicator lamp according to the datasheet draws only 3mA current at 230V AC. Besides the indicator lamp my other loads could be low power as well. So I need to achieve an extra 50mA through relay output pins.
Below is the diagram of the system:
![TkaA4.png TkaA4.png](https://www.edaboard.com/data/attachments/80/80730-54cba73671d21f85060d7d7b891cf887.jpg)
I'm trying to achieve the minimum load current for this AC SSR which is 50mA.
My circuit basically look like this:
![n79cx.png n79cx.png](https://www.edaboard.com/data/attachments/80/80731-7cc7161879be44c8a3b89cd35434eb66.jpg)
Above 68k represents my load which draws only 3mA rms current. 23k is the impedance of the open SSR's snubber at 50Hz to represents the 10mA leakage current.
So the problem is my load which draws 3mA which means less than 50mA will not work with this SSR. I cannot change the SSRs so I need to find a workaround to draw around 50mA more through the SSR. I might also use low power applications so I really need to draw more current through this relay. I guess at this site here at the bottom there is something called a bleeder resistor for such purpose:
The only options I came up with is adding another load in parallel with the original load to enable the SSR.
But for 50mA if I add only a resistor this will be like 4.7k minimum. And this will dissipate around 12W.
But if I add RC series in parallel with my load as shown:
![vkoGW.png vkoGW.png](https://www.edaboard.com/data/attachments/80/80732-d2e58230444d941b5fe733b204f0d8c6.jpg)
Then I get the following plots:
![Untitled.png Untitled.png](https://www.edaboard.com/data/attachments/80/80733-c0d0778ed3313653ed9c01bac0924471.jpg)
Above the power dissipated by the resistor is less than 1W.
So in terms of heating and active power RC solution is better. But I was recommended to chose 100 Ohm and 5uF. But in that case the power dissipated and the drawn current is too much.
So my questions are:
1-) Is my RC values fine for this application? Is it fine to use a 480V AC rated capacitor with a 100 Ohm 10W resistor in my case? What type of capacitor and resistor recommended?
2-) In this forum some are warning about using capacitor for zero crossing SSRs. Does anybody have experience with that?
(I have many of these relays with weak loads so I really would appreciate a suggestion without changing the SSR relays.)
