[SOLVED] help with 16f506 not setting output hi..
ghead
Member level 2
Member level 2
Hi all I've written a volt meter program (in .asm) for use in my car using PIC16F506 (this is first time using '506)
when i run the following code CH0-1 of PORTB and PORTC don't latch at all. I've attached whole program as well as i'm not 100% on my layout.
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
MAIN    ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    movlw 0xFF
    movwf PORTC
    movlw 0xFF
    movwf PORTB
    call  del_3       ;RC0-1 AND RB0-1 DON'T GO HI HERE?????
    call  del_3       ;ALL BUT RB2-3 SHOULD OUTPUT A HI........
    call  del_3
    call  del_3
    clrf PORTC
    clrf PORTB
SUB
    call  ADREAD
    call  CONADR
    call  CONDISP
    call  DISPLAY
    GOTO  SUB
Cheers for any help :)
  • VOLT16F506.txt
is it possible that those i/os configured as analog/comparator input?
Reactions: ghead
    V
    ghead
Yes!!!!! thank you, didn't read thoroughly enough so didn't realize about comparator set on by default :)
