help with 0.75V Reference voltage design
Member level 1
Member level 1
ShangHai,China
hello, anyone. Recently, i want to design a circuit of 0.75V reference voltage. i have researched the majority of the IC manufacturers' material, but i still cannt find a suitable design for my circuit.
could anyone offer some materials about the circuit design? thanks.
I assume you have a limited supply voltage otherwise you could scale a 1.25V one?
Assuming you are designing an IC then there is a 0.5V one here that works down to a Vcc of 0.9V: F27 on page 5-71. The principle can probably be used on a CMOS process as well.
If you just want to buy one off the shelf, I am not sure. National say their LM4140 is available as a custom device down to 0.5V, but that probably doesn't help.
Diodes Inc do a 0.6V one the ZXRE060 although I don't know anything about it.
Keith.
Depends on the accuracy most silicon diodes have a forward voltage drop of around 6-700mv. Gemanium and shotkey diodes are lower. Maybe you could get slightly higher with series diodes and then scale. Depends on the current you need.
Keith.
hey, Keith.thanks for your reply. the material"http://www.diodes.com/datasheets/ZXRE060.pdf" helps me a lot. and i know how to solve it now. really thanks.
Added after 1 minutes:
anyway,thank you.
