help: why my LNA gain is negative(db)?
ssdd
Junior Member level 1
hi,
Are you checking the power gain or voltage gain?
Probably because instead of gain you are getting loss. Have you checked your biasing and matching circuits? What kind of topology are you using?
It would help if you could post your circuit.
    ssdd
HI,friends,
I post my circuit on.
i think the parameters are probably not set right,but i can't find
r2,r3,M3 form the transimpedance stage,
I post another circuit ,you can see this one ,its gain also negative
Added after 3 minutes:
hi ,friends,can you leave you email or msn?thanks
my msn: ss_dengdeng@hotmail.com
nobody?i need your help
Can you plot your DC node voltages and currents?
