wildgoat
Junior Member level 2
waiting for read lock on cadence
the library in solaris is shared,and redhat can mount these files correctly
but when active icfb&,cadence will give information as following:
\w *WARNING* Mon Jul 11 09:04:02 2005 Waiting for read lock on "/[here is path name]/system.lib"
\w Permission denied. File may be locked or if you are running on AFS,
\w you may need to add the 'k' (lock permission) bit to the ACL
what shall i do to solve this peoblem?
