lilac
Junior Member level 1
Hello, everyone!
I want to design a 12bit switched capacitor amplifier with following specs: 12 bit , closed-loop gain is 10, sampling freqency is 10MHz, supply voltage is 3.3V. and power consumption is not very restrict.
I have several questions:
1) To a switched capacitor amplifier, 12 bit means what?
2) Which type of opamps can match this request? and how to decide the specs of the opamps in order to make the amplifier work well under 10MHz sampling freqency?
3) For sampling and hold circuit, which circuit structure is the best choice. Can I use the noninverting structure to realize it ?
