Twerp
Newbie level 3
Hello,
Newly registered, but I've used this site in the past when google has directed me here. I'm trying to reverse engineer a schematic and I have the majority of it completed. There are a few components that have no visible markings making it pretty difficult to find. If I am in the wrong forum area (maybe analog would have been a better choice?), please let me know.
There are three components. Q001 looks to be in a standard SOT-23 package while Q305 and Q306 appear to be in a SOT428 (maybe a SOT89???). So I have checked continuity, diode tested, and ohm'd out the leads, but having difficulty reaching conclusions.
So those last three pictures show my thoughts. The middle pin on the top is connected with the bottom pin for both the Q305/306 components.
Q001: It looks like it is a simple BJT since the diode check showed it was open between the collector and emitter in both directions. The problem with this is that with every diode package I have seen, the base is always in the same position (see below picture). The base in my design will have been in the emitter position. Am I being a bit too paranoid with this component?
Q305: It looks it is a PNP BJT, but I am getting weird readings going across the collector and emitter terminals. I've heard there are prebiased transistors so I believe that is the case for Q305. Correct?
Q306: It looks to be like two diodes in series. The problem is the forward voltage from pins 2 to 3 never really settle. It slowly keeps increasing and I stopped probing at 1.8 volts since there was no sign of stopping.
So I'm basically looking for any indication that I'm on the right track (or completely off). It's difficult to know what's inside these black boxes. Are these packages mostly for discrete components or can IC's be packaged in here as well? (in which case I would really have no way of finding that out).
Thanks for any assistance,
Twerp
Twerp
