HELP :::::: trigonometry PLEASE
other-side-of-d-moon
Full Member level 1
Hello there, are you OK! I hope soooo
Brother and sisters, this is my last problem in my project and so would you please help me and I promise you that I’ll mention your names in my project I swear to ***
So the problem is I want to know the lengths of the lines ( ae ), ( bf ) and ( cg )
Where AED=20.4, BFD= 13.52, CGD=10.8546 and PD= 10.2
Theta 1=30, Theta 2=50, Theta 3=70 and Theta 4= 90
sincerely
The best help I can give you is to advice you to do your project yourself.
Regards
Z
Alright pal try to use angle of depression method to calculate the total length of sides from which you can find the length of lines ae and stuff like that
\[ lenghta = \frac{10.2}{\tan \theta_1} \quad \rightarrow \quad \; ae = \frac{lenghta-5.1}{\cos\theta_1}\]
\[ lenghtb = \frac{10.2}{\tan \theta_2} \quad \rightarrow \quad .......\] Continue
Clearly one or more of values you have provided are incorrect.
The hypotenuse of a right triangle with sides of 5.1 and 10.2, would be 11.40.
Therefore the length of CGD would be greater than this hypotenuse and could not be 10.85.
I would suggest rechecking your values, particularly the sides of the rectangle 5.1 and 10.2.
BigDog
BigDog
Sorry pls recheck the figure again, u r mistaken
tnx Eduardo, i'll check the answer then i'll be in touch with u, tnx Bro
The image you posted clearly shows a rectangle with sides of 5.1 and 10.2, the resulting diagonal of such a rectangle would be 11.40 in length.
For an intersection of segment CGD to occur with the side of the rectangle measuring 10.2, the length of CGD would need to be greater than 11.40, not the 10.85 you stated.
Therefore, you are mistaken, recheck your values.
BigDog
The mistake is what point G does not exist.
I would hesitate in referring to the lack of intersection as a "mistake" rather it is an inevitable consequence of the stated values.
BigDog
