mehdi8310021
Newbie level 2
hi
i can to write in 1G byte sd card with arm at91sam7s64 via spi. but when i chance it with 2G byte sd cart it does not work.:-(
in initializing sd in 1G byte when arm sents 0x00 to sd the 0x01 respond returns from sd but in 2G byte sd cart the 0xFF respond returns from sd.
this is my codes in spi and mmc/sd initialization
thanks for your think
PHP:
[CODE]void initSPI (void)
//PA.11 -> NPCS0
//PA.12 -> MISO
//PA.13 -> MOSI
//PA.14 -> SPCK
s_pPio->PIO_PDR = BIT11 | BIT12 | BIT13 | BIT14;
s_pPio->PIO_ASR = BIT11 | BIT12 | BIT13 | BIT14;
s_pPio->PIO_BSR = 0;
AT91C_BASE_PMC->PMC_PCER=1<<AT91C_ID_SPI;
// pull up resistor
s_pSys->PIOA_PPUER = BIT11 | BIT12 | BIT13;
//s_pPMC->PMC_PCER = AT91C_ID_SPI; //enable the clock of SPI
s_pPMC->PMC_PCER = 1 << AT91C_ID_SPI;
/**** Fixed mode ****/
s_pSpi->SPI_CR = 0x81; //SPI Enable, Sowtware reset
s_pSpi->SPI_CR = 0x01; //SPI Enable
s_pSpi->SPI_MR = 0xE0011; //Master mode, fixed select, disable decoder, FDIV=0 (MCK), PCS=1110
s_pSpi->SPI_CSR[0] = 0x0802; //8bit, CPOL=0, ClockPhase=1, SCLK = 200kHz
// s_pSpi->SPI_CSR[0] = 0x0202; //8bit, CPOL=0, ClockPhase=1, SCLK = Max
#ifdef SPI_PDC_Transfer_Mode
s_pPDC->PDC_PTCR = AT91C_PDC_TXTEN | AT91C_PDC_RXTEN;
#endif
s_pSpi->SPI_PTCR = AT91C_PDC_TXTEN | AT91C_PDC_RXTEN;
// Initialization
char initMMC (void)
//raise SS and MOSI for 80 clock cycles
// >>> SendByte(0xff) 10 times with SS high
//RAISE SS
char response=0x01;
// dbgu_print_ascii("Start iniMMC......");
initSPI();
//initialization sequence on PowerUp
//CS_HIGH();
for(int i=0;i<=18;i++)
spiSendByte(0xff);
//CS_LOW();
//Send Command 0 to put MMC in SPI mode
for(int i=0;i<=19;i++){
mmcSendCmd(0x00,0,0x95);
if(mmcGetResponse()==0x01){
/*222222222 glcd_Text(5,31, FONT_SEVEN_DOT,"yes Responses");
glcd_UpdateAll();*/
break;
if(i>=0x18){
/* 11111111111 for(int h=0;h<=19;h++){
glcd_Text(5,31, FONT_SEVEN_DOT,"No Response");
glcd_UpdateAll();
h=h+1;
//Now wait for READY RESPONSE
while(response==0x01)
// dbgu_print_ascii("Sending Command 1");
/* 11111111111 glcd_Text(5,15, FONT_SEVEN_DOT,"Sending Command 1");
glcd_UpdateAll();*/
//CS_HIGH();
spiSendByte(0xff);
//CS_LOW();
mmcSendCmd(0x01,0x00,0xff);
response=mmcGetResponse();
//CS_HIGH();
spiSendByte(0xff);
glcd_Text(5,18, FONT_SEVEN_DOT,"MMC INITIALIZED");
glcd_UpdateAll();
// dbgu_print_ascii("MMC INITIALIZED AND SET TO SPI MODE PROPERLY.");
return MMC_SUCCESS;
}[/CODE]
