Help to simpliy a Fuji Flash Block to use it for fun
highfreqv
Helo, i have a flash block from a finepix s1000 camera, and i want to put a simple two wire to power the flash lamp and a switch on/off to charge discharge the lamp/capacitor (it's a big one :) -190uF/330V) and make flashes.
I have marked in the attachement picture the damaged zone (connectors, wire) that cant be used any more (need to get other and simple point on pcb to sold the battery power and the switch).I want to simplify the battery power conection and the switch very simple without those IC, and other unusefull elements or circuit's.Hope for a idea.Thanks.
Attached: Finepix 5000s schematic
: Damaged part from block (photo)
Note: the flash lamp connector has 4 wire, first(1) red last(4) black second(2) white, and green(3)
the green and white goes on the 2 termination of the flash lamp
the red and black goes on a smal pcb with a very small coil (named t1), and from coil goes a smal wire on the lateral side of the flash lamp that is partially wrapped with metalic paper.
  • FUJI FinePix S5000 SM.pdf
