mastertushar
Member level 3
- Joined
- May 5, 2010
- Messages
- 56
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Mumbai, India
- Activity points
- 1,651
In your opening post you said twice you are using WinPic software - is this correct ?
Art2003 Hardware is listed in the Hardware Configuration section of the WinPic800 software - totally different from WinPic.
Please clarify which program you are using .
Are you using a Desktop PC or a Laptop ? - laptop USB ports can cause problems due to there +5v current being too low.
The other common problem is D- and D+ lines being the wrong way round.
Noticed in that diagram C4 is shown as .47uf / 0.1uf - it needs .47uf.
i used C4 0.1uF .... ok wait i m try to use by 0.47 uF
ohhhps.. now my PIC is not erasing by ART2003... i cant understand why?
i come to know i wasted my PIC18F2550 before it by continuously programming and erasing .. now it not got erased..
Don't think so, you can program and erase the chip thousands of times.
You many have damaged it by wrong voltages etc.
When you start the programmer software , does it correctly auto dectect the 2550 ?
When you used the JDM does that also recognise the chip.
The JDM is normally a high voltage programmer, have you turned off the LVP options in the programmer software ?
eems your problem is still down to the hardware programmers - so while you wait for a new 2550 why don't you see if you can buy a different Pic chip in the market and try and get / prove your programmer is working with that, so you know its ok before you get the new 2550.
