Your soft starter turns Q3 on which turns Q2 off, and Q2 being off means that Q4 is off…..that is a problem because Q4 is what you rely on to “brake” your smps.
Also,I don’t see a RC snubber across your sec diode.
I think what you need to do is just first of all set it up as a simple 28vout smps, and put a load on of 28v/1.4a…then when you have it working like that you can go forward.
So go back into “power calc”, (or whatever powerint call it), and do a design for 28vout and 1.4a out, and solder that circuitry in and then go from there….it will probably give you a tl431 circuit.
I woudl put your bjt based soft starter and current (amps) regulator circuit into ltspice and check it out in there.
Also, is your c14 too big?......what is its value....what does your control pin voltage look like...is it rising up quick enough?......if not then youre into max peak current threshold territory
