HELP: simple TRIGONOMETRY
Rihanna
Junior Member level 1
Hello my friends, How Are yoU toDay ;) I have a question for you guys and i hope you to guide me to the correct answer
The path from the satellite to the earth station can be found as
(hs-he)/sin(theta) if theta >or= 5 degrees
where "hs" is satellite height and "he" is the earth station height
while the path equals
2(hs-he)/[{sin^2(theta)+(2(hs-he)/Re}^1/2}+sin(theta)] if theta < 5 degrees
Why? i mean what is the difference between those tow condition ( Please take into account the earth curvature Re = 8500 Km)
I would guess that the second equation is more accurate, but the first (simpler) equation gives results that are "close enough" when theta >= about 5 degrees.
i.e. First equation is an approximation that's fairly accurate for theta >= about 5 degrees.
Thanks a lot Mr.godfreyl for your answer, but could you please explain to me in more details please
Sincerely
Hi Rihanna
By "path", I assume you mean the distance between the satellite and the earth station. In that case the first equation would be perfectly accurate if the world was flat, as shown in the diagram below.
Unfortunately, the world isn't flat so that equation doesn't work very well. Playing around in a spreadsheet, it seems like it's not only very inaccurate for low values of theta, but also if the satellite is too high. e.g. For a geostationary satellite, hs= 35,786 kilometers, and that equation is nowhere near accurate even for theta = 30 degrees (assuming I managed to figure out the correct answer).
Unfortunately the second equation you gave is wrong too. Maybe you made a mistake copying it or maybe I made a mistake in the spreadsheet, but either way I don't get good answers with it.
As best as I can figure it out, the correct equation is:
Path = 0.5*(-B+(B^2-4*C)^0.5)
where:
B = 2*Re*SIN(theta)
C = -((H+Re)^2-Re^2)
where:
H = height of satellite above ground
Re = radius of earth = 64000km, not 85000km
I ignored he, assuming the earth station is at ground level.
Cheers - Godfrey
Hi Rihanna
where:
B = 2*Re*SIN(theta)
where:
Cheers - Godfrey
Tnx a lot godfrey for your efforts to helping me. However can you please give me the spreadsheet calculation, i want to understand wt you have calculated and how did you get the formula you gave me,
regards, Rihanna
