[help!!] signal delay via RS422 interface
etrobin
Member level 1
Member level 1
Dear all,
Here is the configuration!!!
One 100m Cat5 10baseT patch cable (24AWG) used to connect RS422 driver and receiver!!! The signals "clock" and "data" be tarnsmitted by this interface!!!
My problem is "data" can't be catched correctly at rising edge of "clock" when data rate up to 10Mbps!!! If this is possible caused by different propagation delay???
Any advise???
Thank you for reply!!!
regards,
etrobin
Hi
Use equalizer circuit and line booster every 20 meter to solve your problem
look for CLC014 from national : www.national.com
All the best
Bobi
