Help! SigGen with this error message
dionysus
Newbie level 5
Newbie level 5
The equipment is Anritsu Wiltron 68347B Synthesized Signal Generator.
The error message is "Fine Loop Osc Failed"
I can't find this product from their site. There's no manual with me either. Judging from the failure, I believe it could be an internal component failure. Please shed some light if this is some config corruption or sumthin else? Reset and reboot couldn't help. Self test return this error message.
Please advice.
Cheers,
dionysus
Yes, it is probably a component failure causing the loop not to lock and this status is picked up by the units diagnostics. It may be simple to repair but you need the service manual to look at the circuit. You should be able to get a service manual from the agents for the product. It won't be free
You can also try http://www.manualsplus.com
I have used them in the past
Yeah, I believe it is still functional-able but will not be fine-tunable and there's discrepancies on stability and accuracy issues. I'll look further and post the update here, so that future readers of this thread can avoid this "could be expensive' mistake. Actually still in the dark of how I get this...another red alert given to me by my colleague :( Input from all others much appreciated.
Cheers,
dionysus.
